メインコンテンツへスキップ
CAIQUM-7119:README included in AIQUM installer archives for RHEL8 include:「Upgrade instructions are not applicable for Red Hat Enterprise Linux 8」
89
Visibility:
Votes:
0
Category:
active-iq-unified-manager
Specialty:
om
Last Updated:
問題
  • このチケットはドキュメントの修正のために作成されました。
  • ActiveIQUnifiedManager-9.XX-el8.zip のREADME には、次のテキストが含まれています。
To upgrade from a prior version of the software please use the pre-check
command to ensure that all the requirements are met.  The upgrade process
requires several steps, and cannot be performed using yum alone.
Note: Upgrade instructions are not applicable for Red Hat Enterprise Linux 8. You can only install Unified Manager on an RHEL 8 systems, and not upgrade.
New to NetApp?
