メインコンテンツへスキップ
AIQUMがクラスタ監視の停止を検出し、すべてのノードの情報を収集できない
34
Visibility:
Votes:
0
Category:
active-iq-unified-manager<a>2010005481</a>
Specialty:
om
Last Updated:
環境
  • Active IQ Unified Manager(AIQUM) 9.13P1
  • ONTAP 9
問題
  • AIQUMが Cluster Monitoring is stuck イベントを検出:
Monitoring is stuck for the cluster <CLUSTER>. Reason: Monitoring completion time exceeded. Monitoring StartTime: <TIMESTAMP>, Monitoring EndTime: <TIMESTAMP>. Contact AIQUM technical support.
  • AIQUMが すべてのONTAPクラスタの情報を収集できない
  • ocumserver.log データ収集中のタイムアウトを示します。
ERROR [oncommand] [reconciliation-1] [<CLUSTER>(incremental@13:50:42.775)|complete] [c.n.d.c.CollectionCompletionNotifier] Timeout occurred while waiting on collection completion listener ClusterSparesEventDetector..EnhancerBySpringCGLIB..a7e633af. Cancelling it so that others can continue.
INFO  [oncommand] [collection-completion-sync-8] [c.n.d.c.r.SnapmirrorTableCompletionListener] SnapmirrorRelationship Table is updated after collection completion for cluster <CLUSTER>
INFO  [oncommand] [reconciliation-1] [<CLUSTER>(incremental@13:50:42.775)|complete] [c.n.d.c.CollectionCompletionNotifier] Collection completion notification for cluster <CLUSTER>(inventory.ontap.fas.Cluster:1910729) finished in 0:15:00.625.
INFO  [oncommand] [reconciliation-1] [<CLUSTER>(incremental@13:50:42.775)] [com.netapp.dfm.collector.LockUtils] Releasing reconciliation-processing lock(java.util.concurrent.locks.ReentrantReadWriteLock$WriteLock@32cddd9e[Locked by thread reconciliation-1]) for 51
ERROR [oncommand] [reconciliation-1] [<CLUSTER>(incremental@13:50:42.775)] [c.n.dfm.collector.OcieJmsListener] Inventory change listener error
java.util.concurrent.TimeoutException: null
   at java.base/java.util.concurrent.FutureTask.get(FutureTask.java:204)
   at deployment.dfm-app.war//com.netapp.dfm.collector.CollectionCompletionNotifier.notifyListeners(CollectionCompletionNotifier.java:320)
   at deployment.dfm-app.war//com.netapp.dfm.collector.OcieJmsListener.reconcileAndNotify(OcieJmsListener.java:1322)
   at deployment.dfm-app.war//com.netapp.dfm.collector.OcieJmsListener.reconcileDataSourceChanges(OcieJmsListener.java:1009)
   at deployment.dfm-app.war//com.netapp.dfm.collector.OcieJmsListener.handleChangeMessage(OcieJmsListener.java:976)
   at deployment.dfm-app.war//com.netapp.dfm.collector.OcieJmsListener$2.run(OcieJmsListener.java:483)
   at deployment.dfm-app.war//com.netapp.dfm.common.metrics.executor.ThreadPoolMonitorExecutor.lambda$submit$1(ThreadPoolMonitorExecutor.java:179)
   at java.base/java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:515)
   at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264)
   at deployment.dfm-app.war//com.netapp.dfm.common.metrics.executor.ThreadPoolMonitorExecutor.lambda$execute$0(ThreadPoolMonitorExecutor.java:165)
   at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128)
   at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628)
   at java.base/java.lang.Thread.run(Thread.java:829)
  • journalctl 多数のレート制限超過メッセージを報告します。
<AIQUM_HOST> kernel: Rate limit exceeded: IN=eth0 OUT= MAC=<MAC_ADDRESS> SRC=<IP> DST=<AIQUM_IP> LEN=52 TOS=0x02 PREC=0x00 TTL=124 ID=32617 DF PROTO=TCP SPT=64078 DPT=443 WINDOW=8192 RES=0x00 CWR ECE SYN URGP=0
New to NetApp?
