メインコンテンツへスキップ
Data ONTAP ハードウェアプロバイダのユーザ名パスワードが変更または変更されると、 SnapCenter Plug-In for Exchange Backup が失敗します
116
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
snapx
Last Updated:
環境
  • SnapCenter Server
  • SnapCenter Plug-in for Microsoft Exchange ( SCE )
問題
SCE バックアップは、「 VSS_E_provider_拒否 」というエラーで失敗します
Failed to create VSS snapshot [Error Code: -2147212538] [VSS_E_PROVIDER_VETO] [Error Code: -2147212538] [VSS_E_PROVIDER_VETO] Possible solution: Please check if there is adequete space available on the LUNs.
SCE バックアップが失敗し、次のエラーメッセージが表示されます
04:00:26.2559859-04:00 Error SCE PID=[2412] TID=[7980] Operation failed [Error code: -2147212538]
04:00:26.2559859-04:00 Verbose SCE PID=[2412] TID=[7980] --VSSRequestor::LoopWait
04:00:26.2759880-04:00 Error SCE PID=[2412] TID=[7980] Failed to create VSS snapshot [Error Code: -2147212538] [VSS_E_PROVIDER_VETO]
04:00:26.2969885-04:00 Verbose SCE PID=[2412] TID=[7980] --VSSRequestor::CreateVssSnapshot
04:00:26.2969885-04:00 Error SCE PID=[2412] TID=[7980] Failed to create VSS snapshot [Error Code: -2147212538] [VSS_E_PROVIDER_VETO] [Error Code: -2147212538] [VSS_E_PROVIDER_VETO]
04:00:26.2969885-04:00 Verbose SCE PID=[2412] TID=[7980] --VSSRequestor::Backup
04:00:26.2979890-04:00 Verbose SCE PID=[2412] TID=[7980] sceBackupInfoList.Count = 0
04:00:26.2979890-04:00 Verbose SCE PID=[2412] TID=[7980] Releasing backup lock
04:00:26.2989932-04:00 Error SCE PID=[2412] TID=[7980] Failed to create VSS snapshot [Error Code: -21
New to NetApp?
