メインコンテンツまでスキップ
Java 7 を使用するアプリケーションは、の後でデータをアップロードできません 11.2 または 11.3 へのアップグレード
45
Visibility:
Votes:
0
Category:
storagegrid
Specialty:
sgrid
Last Updated:
に適用されます
StorageGRID 11.2
StorageGRID 11.3
問題
Java 7 のアプリケーションはデータをアップロードできません 11.2 または 11.3 にアップグレードしたあとで StorageGRID にアップグレードします
17:48:18.386 [ERROR] createWithOnePart:204 - Object create fail (with com.amazonaws.AmazonClientException):com.amazonaws.AmazonClientException: Unable to execute HTTP request: Remote host closed connection during handshake
   at com.amazonaws.http.AmazonHttpClient$RequestExecutor.executeHelper(AmazonHttpClient.java:956)
   at com.amazonaws.http.AmazonHttpClient$RequestExecutor.doExecute(AmazonHttpClient.java:661)
   at com.amazonaws.http.AmazonHttpClient$RequestExecutor.executeWithTimer(AmazonHttpClient.java:635)
Caused by: javax.net.ssl.SSLHandshakeException: Remote host closed connection during handshake
   at sun.security.ssl.SSLSocketImpl.readRecord(SSLSocketImpl.java:946)
   at sun.security.ssl.SSLSocketImpl.performInitialHandshake(SSLSocketImpl.java:1312)
   at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1339)
   at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1323)
   at org.apache.http.conn.ssl.SSLConnectionSocketFactory.createLayeredSocket(SSLConnectionSocketFactory.java:394)
   at org.apache.http.conn.ssl.SSLConnectionSocketFactory.connectSocket(SSLConnectionSocketFactory.java:353)
   at com.amazonaws.http.conn.ssl.SdkTLSSocketFactory.connectSocket(SdkTLSSocketFactory.java:132)
   at com.amazonaws.http.AmazonHttpClient$RequestExecutor.executeOneRequest(AmazonHttpClient.java:1099)
   at com.amazonaws.http.AmazonHttpClient$RequestExecutor.executeHelper(AmazonHttpClient.java:948)
   ... 31 more
Caused by: java.io.EOFException: SSL peer shut down incorrectly
   at sun.security.ssl.InputRecord.read(InputRecord.java:482)
   at sun.security.ssl.SSLSocketImpl.readRecord(SSLSocketImpl.java:927)
   ... 53 more
 from [10.104.101.43]
New to NetApp?
Scan to view the article on your device
