メインコンテンツへスキップ
ストレージコントローラの SANtricity OS のアップグレードが RuntimeError によって失敗します SYSTEM_ERR
7
Visibility:
Votes:
0
Category:
storagegrid<a>2008658465</a>
Specialty:
sgrid
Last Updated:
環境
  • NetApp StorageGRID 11.4 以降
  • NetApp StorageGRID アプライアンス
問題
  • ストレージコントローラのSANtricity OSのアップグレードが次のエラーで失敗する:
Error: Fatal installation failure - SANtricity OS staging failed with: RuntimeError: Union <<class 'SYMbol.parser.RpcAcceptedReplyBody'>> at 0xXXXXXXXXXXXX> discriminator value SYSTEM_ERR does not have a corresponding qualifier
  • gdu-server.log のプライマリ管理ノードでエラーが表示される。
 INFO -- gdu-server: Invalidating any staged SANtricity OS on <NODE>
 INFO -- gdu-server: 1% SANtricity OS staging done.
 INFO -- gdu-server: Staging SANtricity OS on <NODE>
 INFO -- gdu-server: 2% SANtricity OS staging done.
 INFO -- gdu-server: WARNING -- Union <<class 'SYMbol.parser.RpcAcceptedReplyBody'>> at 0xXXXXXXXXXXXX> discriminator value SYSTEM_ERR does not have a corresponding qualifier
 INFO -- gdu-server: RuntimeError: Union <<class 'SYMbol.parser.RpcAcceptedReplyBody'>> at 0xXXXXXXXXXXXX> discriminator value SYSTEM_ERR does not have a corresponding qualifier
ERROR -- gdu-server: SANtricity OS staging failed with: SANtricity OS precheck successful.
Invalidating any staged SANtricity OS.
 ERROR -- gdu-server: SANtricity OS staging failed with: RuntimeError: Union <<class 'SYMbol.parser.RpcAcceptedReplyBody'>> at 0xXXXXXXXXXXXX> discriminator value SYSTEM_ERR does not have a corresponding qualifier (Bycast::Tasks::GduServer::SoftwareUpdate::InstallError)
  INFO -- gdu-server: Software update task complete at <TIMESTAMP>
 ERROR -- gdu-server: Failed to apply SANtricity OS to <NODE>: Fatal installation failure - SANtricity OS staging failed with: RuntimeError: Union <<class 'SYMbol.parser.RpcAcceptedReplyBody'>> at 0xXXXXXXXXXXXX> discriminator value SYSTEM_ERR does not have a corresponding qualifier
 ERROR -- gdu-server: Failure occurred during Software Update
  • /base-os-logs/var/log/eos-system-status でエラー SYSTEM_ERR が繰り返し表示されるノードは次のとおりです。
Error while running status update. Union <<class 'SYMbol.parser.RpcAcceptedReplyBody'>> at 0xXXXXXXXXXXXX> discriminator value SYSTEM_ERR does not have a corresponding qualifier
Error connecting to SYMbolAPI. Union <<class 'SYMbol.parser.RpcAcceptedReplyBody'>> at 0xXXXXXXXXXXXX> discriminator value SYSTEM_ERR does not have a corresponding qualifier
  • web-server-trace-log.txt ストレージコントローラの出力に次のような情報が表示される場合、WebServerサービスは10分おきに定期的に再起動されます。
INFO [main] c.l.a.w.s.WebServer [WebServer.java:2292] [requestId=0, deviceId=N/A] stdout: Starting web server
New to NetApp?
