メインコンテンツまでスキップ
バッテリ(「BAT初期FCC」読み取り不能)が重要な場合は、ご自宅にお問い合わせください
77
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
HW
Last Updated:
環境
  • FAS8060
  • AFF 8060
問題
マザーボードの交換後、ONTAP のブートプロセス中に次のエラーメッセージが報告されます。
[Node01:nvram.battery.sensor.unreadable:EMERGENCY]: The NVRAM battery state cannot be determined because the 'Bat Initial FCC' sensor is unreadable. To prevent data loss, the system will shut down in 5 minutes.
[Node01:callhome.battery.failure:EMERGENCY]: Call home for BATTERY ('Bat Initial FCC' unreadable) CRITICAL.
[nvram.hw.initFail:CRITICAL]: NVRAM hardware initialization failed: DDR DIMM is not present or failed to train.
*              CRITICAL ERROR              *
* NVRAM has detected errors. Ontap cleared the error.       *
* Data loss is likely.                       *
New to NetApp?
