シャーシの電力が低下している:P1.2Vスタンバイがクリティカル低(0mV)
環境
- FAS2720
- ベースボード管理コントローラ
問題
- 毎時のEMSアラート:
例:
Time Node Severity Event
5/20/2021 23:14:59 node-01 ALERT monitor.chassisPower.degraded: Chassis power is degraded: P1.2V Standby is critical low (0 mV).
5/20/2021 22:14:58 node-01 ALERT monitor.chassisPower.degraded: Chassis power is degraded: P1.2V Standby is critical low (0 mV).
5/20/2021 21:14:58 node-01 ALERT monitor.chassisPower.degraded: Chassis power is degraded: P1.2V Standby is critical low (0 mV).
5/20/2021 20:14:57 node-01 ALERT monitor.chassisPower.degraded: Chassis power is degraded: P1.2V Standby is critical low (0 mV).
5/20/2021 19:14:56 node-01 ALERT monitor.chassisPower.degraded: Chassis power is degraded: P1.2V Standby is critical low (0 mV).
5/20/2021 18:14:55 node-01 ALERT monitor.chassisPower.degraded: Chassis power is degraded: P1.2V Standby is critical low (0 mV).
5/20/2021 17:14:54 node-01 ALERT monitor.chassisPower.degraded: Chassis power is degraded: P1.2V Standby is critical low (0 mV).
5/20/2021 16:14:53 node-01 ALERT monitor.chassisPower.degraded: Chassis power is degraded: P1.2V Standby is critical low (0 mV).
- プラットフォームセンサー出力:
例:
Node Sensor State Value/Units Crit-Low Warn-Low Warn-Hi Crit-Hi
node-01
PVCCIN CPU normal
1785 mV 1249 1501 1900 2005
P5V STBY normal
4966 mV 4264 4368 5694 5824
P5V normal
5070 mV 4264 4368 5694 5824
PVDDQ DDR4 AB normal
1221 mV 1086 1100 1299 1320
P1.2V Standby
crit-low
0 mV 1086 1100 1299 1398
- 問題 はBMCのリブート後も維持されます。
