メインコンテンツへスキップ
FAS2xxx 環境シャットダウン(バッテリ PCT 容量が危険)
82
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
hw
Last Updated:
環境
  • FAS2620
  • FAS2650
  • FAS2750
  • FAS2720
  • NVMEMバッテリ
問題
  • NVMEMバッテリーエラーによるノードダウン。
[cluster01:nvmem.battery.capLowCrit:EMERGENCY]: The NVMEM battery capacity is critically low (0 cycles). To prevent data loss, the system will shut down in 20 minutes.
[cluster01:callhome.battery.failure:EMERGENCY]: Call home for BATTERY (capacity low) CRITICAL.
[cluster01:callhome.battery.failure:EMERGENCY]: Call home for BATTERY (full charge capacity low) CRITICAL.
[cluster01:monitor.shutdown.emergency:EMERGENCY]: Emergency shutdown: Environmental Reason Shutdown (Battery PCT capacity critical)
  • event all NVMEMバッテリ学習サイクルの開始後、SPのコマンドでノードダウンが表示される。
Record 1847: Wed Jul 24 12:00:13 2024 [IPMI.notice]: 3501 | 02 | EVT: 0301ffff | Bat_Lrn_Active | Assertion Event, "State Asserted"
Record 1862: Wed Jul 24 13:18:38 2024 [IPMI.emergency]: env_mgr triggers storage OS halt: Battery PCT
Record 1865: Wed Jul 24 13:19:04 2024 [IPMI.notice]: 4501 | 02 | EVT: 6f406fff | Sensor 255 | Assertion Event, "Storage OS stop/shutdown"
  • system power cycle をSPから実行しても問題は解決せず、ノードの電源ステータスはオフと表示されます。
SP cluster01> system power cycle
This command will trigger a destage of ONTAP and will take some time to complete after which the system will restart.
Use "system reset" or "system reset current" to avoid the delay. Continue? [y/n] y
SP cluster01>
SP cluster01> system power status
Host Power is off
New to NetApp?
