メインコンテンツへスキップ
メンテナンスまたは交換後のシェルフセンサーのしきい値が正しくない
48
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
HW
Last Updated:
環境
  • FAS システム
  • AFF システム
問題
ハードウェアの保守/交換後、環境ログに記録されるシェルフセンサーのしきい値が正しくありません。これは1つのノードのみが誤って報告しており、パートナーは正しく報告しています。
例:
Temperature thresholds by element: [1] High critical: 52 C (125 F); high warning: 47 C (116 F) Low critical: 0 C (32 F); low warning: 5 C (41 F) [2] High critical: 60 C (140 F); high warning: 55 C (131 F) Low critical: 0 C (32 F); low warning: 5 C (41 F) [3] High critical: 60 C (140 F); high warning: 55 C (131 F) Low critical: 0 C (32 F); low warning: 5 C (41 F) [4] High critical: 60 C (140 F); high warning: 55 C (131 F) Low critical: 0 C (32 F); low warning: 5 C (41 F) [5] High critical: 60 C (140 F); high warning: 55 C (131 F) Low critical: 0 C (32 F); low warning: 5 C (41 F) [6] High critical: 62 C (143 F); high warning: 57 C (134 F) Low critical: 5 C (41 F); low warning: 10 C (50 F) [7] High critical: 100 C (212 F); high warning: 95 C (203 F) Low critical: 5 C (41 F); low warning: 10 C (50 F) [8] High critical: 62 C (143 F); high warning: 57 C (134 F) Low critical: 5 C (41 F); low warning: 10 C (50 F) [9] High critical: 100 C (212 F); high warning: 95 C (203 F) Low critical: 5 C (41 F); low warning: 10 C (50 F) [10] High critical: 90 C (194 F); high warning: 80 C (176 F) Low critical: 0 C (32 F); low warning: 5 C (41 F) [11] High critical: 100 C (212 F); high warning: 79 C (174 F) Low critical: 0 C (32 F); low warning: 5 C (41 F) [12] High critical: 75 C (167 F); high warning: 60 C (140 F) Low critical: 0 C (32 F); low warning: 5 C (41 F) [13] High critical: 65516 C (117960 F); high warning: 65516 C (117960 F) Low critical: 65516 C (117960 F); low warning: 65516 C (117960 F) [14] High critical: 65516 C (117960 F); high warning: 65516 C (117960 F) Low critical: 65516 C (117960 F); low warning: 65516 C (117960 F) [15] High critical: 65516 C (117960 F); high warning: 65516 C (117960 F) Low critical: 65516 C (117960 F); low warning: 65516 C (117960 F)
New to NetApp?
