メインコンテンツへスキップ
PSUがシェルフの電源が中断されたアラートで重大なステータスを報告
205
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
環境
  • FAS / AFFシステム
  • ディスク シェルフ
  • 電源装置(PSU)
問題
  • イベントログでは次のアラートが報告されます。
[Node-A: statd: monitor.shelf.fault:alert]: Critical fault reported on disk storage shelf attached to channel 0a. Check fans, power supplies, disks, and temperature sensors.
[Node-A: statd: callhome.shlf.fault:error]: Call home for SHELF_FAULT
[Node-A: dsa_worker4: ses.status.psError:alert]: DS212-12 (S/N SHFNCXXXXXXXXXX) shelf 0 on channel 0b power error for Power supply 2: critical status; AC Fail. This module is on the rear of the shelf at the bottom right.
[Node-A: dsa_worker4: callhome.shlf.power.intr:error]: Call home for SHELF POWER INTERRUPTED
  • ストレージシェルフで次のエラーが発生します。
Cluster1::> storage shelf show -errors
   Shelf Name: 1.0
   Shelf UID: 50:0a:09:XX:XX:XX:XX:XX
 Serial Number: SHFNCXXXXXXXXXX
Error Type       Description
Power        Critical condition is detected in storage shelf power supply unit "2". The unit might fail.
Voltage       Critical error detected in voltage sensor "4". Sensor is located in the rear of the shelf on the                    lower right power supply.
Voltage       Critical error detected in voltage sensor "3". Sensor is located in the rear of the shelf on the                    lower right power supply.
  • storage show fault の出力で、電源装置のステータスがFAILEDと報告されます。
Cluster1::> system node run -node <node> -command storage show fault
Enclosure Status: unrecoverable
Channel: 0a
Shelf: 0
Shelf Type: DS224-12
Product Serial Number: SHFNCXXXXXXXXXX
Module Type: IOM12
Power Supplies:
Element Status      Status Bytes  Status Descriptions
  1: OK         01,00,00,20   RQSTED ON
 2: CRITICAL      02,00,00,F3   DC FAIL, AC FAIL, OFF, RQSTED ON, FAIL
Enclosure:
  1: OK         01,00,02,00  FAIL
  • 環境ステータスレポート:
Cluster1::>system node run -node <nodename> -command environment status
Channel: 2a
Shelf: 11
SES device path: local access: 2a.11.99
Module type: IOM6; monitoring is active
Shelf status: unrecoverable condition
SES Configuration, shelf 11:
 logical identifier=
 vendor identification=NETAPP
 product identification=DS4246
 product revision level=0211
Vendor-specific information:
 Product Serial Number: SHJSG1234000011
Status reads attempted: 9955419; failed: 0
Control writes attempted: 0; failed: 0
Shelf bays with disk devices installed:
  23, 22, 21, 20, 19, 18, 17, 16, 15, 14, 13, 12, 11, 10, 9, 8, 7, 6, 5, 4, 3, 2, 1, 0
  with error: none
Power Supply installed element list: 1, 2, 3, 4; with error: 2
Power Supply information by element:
  [1] Serial number: PMW87654321D3DE  Part number: 0082562-22
    Type: 9C
    Input voltage: <N/A>
    Firmware version: 0311  Swaps: 0
  [2] Serial number: PMW87654321D801  Part number: 0082562-22
    Type: 9C
  [3] Serial number: PMW87654321D757  Part number: 0082562-22
    Type: 9C
  [4] Serial number: PMW87654321C2DD  Part number: 0082562-22
    Type: 9C
Voltage Sensor installed element list: 1, 2, 3, 4, 5, 6, 7, 8; with error: 4
Shelf voltages by element:
  [1] 5.01 Volts  Normal voltage range
  [2] 12.03 Volts  Normal voltage range
  [3] 3.02 Volts  Normal voltage range
  [4] <N/A> sensor condition <N/A>
  [5] 5.01 Volts  Normal voltage range
  [6] 12.03 Volts  Normal voltage range
  [7] 5.01 Volts  Normal voltage range
  [8] 12.03 Volts  Normal voltage range
New to NetApp?
  • この記事は役に立ちましたか?
