メインコンテンツへスキップ
EMS アラート:ディスク シェルフのシェルフ冷却ユニットが故障しました
143
Visibility:
Votes:
0
Category:
disk-shelves
Specialty:
HW
Last Updated:
環境
  • ファンアラート
  • ストレージシェルフ
    • これには、コントローラシャーシに組み込まれたシェルフが含まれます
問題
コントローラーまたはシェルフシャーシのファンがCriticalエラーを報告している。例:
  • NS224シェルフ:
[ses.status.fanError:EMERGENCY]: NS224NSM100 (S/N SHFNxxxxxx) shelf 0 on channel 0x cooling fan error for Cooling element 15: critical status; fan is off. This element is on the unknown location.
[callhome.shlf.fan:EMERGENCY]: Call home for SHELF COOLING UNIT FAILED
  • DS460Cシェルフ:
[ses.status.fanError:EMERGENCY]: DS460-12 (S/N ****) shelf 1 on channel 0a cooling fan error for Cooling element 3: critical status; fan is off. This module is on the rear of the shelf to the left.
[statd: monitor.shelf.fault:alert]: Critical fault reported on disk storage shelf attached to channel 0a. Check fans, power supplies, disks, and temperature sensors.
[statd: callhome.shlf.fault:error]: Call home for SHELF_FAULT
  • DS224Cシェルフ:
[ses.status.fanError:EMERGENCY]: DS224-12 (S/N ****) shelf 0 on channel 0b cooling fan error for Cooling element 1: critical status; fan is off. This module is on the rear of the shelf on the lower left power supply.
  • DS2246シェルフ:
[ses.status.temperatureInfo:info]: DS2246 (S/N ****) shelf 12 on channel 0a temperature information for Temperature sensor 4: normal status.
[monitor.shelf.fault:alert]: Critical fault reported on disk storage shelf attached to channel 0a. Check fans, power supplies, disks, and temperature sensors.
  • コントローラシャーシにシェルフを組み込む:
::> event log show -event *fan*
... monitor.shelf.fault: Critical fault reported on disk storage shelf attached to channel 0a. Check fans, power supplies, disks, and temperature sensors.
... callhome.c.fan.fru.fault: Call home for CHASSIS FAN FRU FAILED: Multiple fans have failed
... monitor.globalStatus.critical: Multiple fans has failed. Power Supply Status Critical: PSU1.
... callhome.fans.failed: Call home for MULTIPLE FAN FAILURE
... monitor.globalStatus.critical: Multiple fans has failed. Power Supply Status Critical: PSU1. Disk shelf fault.
... monitor.fan.critical: 2 fans have failed. Replace them to avoid overheating. If not corrected, system will shutdown in 2 minutes.
... monitor.fan.failed: One fan has failed.
CTTI_NFS::> system node environment sensor show
Node Sensor     State  Value/Units ...
node PSU1 Fan 1 normal 0 RPM       ...
     PSU1 Fan 2 normal 7500 RPM    ...
     PSU_FAN    fault  FAIL_1
  • AutoSupport STORAGE-FAULTセクション(または「storage show fault -v”」コマンド)にFANのステータスが表示されます CRITICAL例:
Fans:
Element Status         Status Bytes  Status Descriptions
1: OK                01,05,16,A7
2: OK                01,04,50,A5
3: CRITICAL          02,01,BC,A1
4: OK                01,04,68,A5
             場合によってはステータスが「OFF, FAIL」と表示されることもあります
              Fans:
1: CRITICAL          02,00,00,F0     OFF, FAIL
2: CRITICAL          02,00,00,F0     OFF, FAIL
3: CRITICAL          02,00,00,F0     OFF, FAIL
4: CRITICAL          02,00,00,F0     OFF, FAIL
5: OK                01,05,13,A6
  • AutoSupport ENVIRONMENTセクション()は、RPMが異常であることを示しています。例:
Cooling Unit installed element list: 1, 2, 3, 4, 5, 6, 7, 8; with error: 3
Cooling Units by element:
[1] 12840 RPM
[2] 11160 RPM
[3] 0 RPM
[4] 11130 RPM
  • ファンを再装着しても状況は解決しない
New to NetApp?
  • この記事は役に立ちましたか?
