メインコンテンツへスキップ
NS224 のセンサー 7 またはセンサー 13 温度超過警告
74
Visibility:
Votes:
0
Category:
disk-shelves
Specialty:
hw
Last Updated:
環境
  • NS224シェルフ
  •  02.10より前のファームウェアバージョンを実行しているNSM100モジュール
問題
  • センサー7または13の過熱(NSMモジュールAまたはBのCPUセンサー)
[node_name: dsa_worker4: ses.status.temperatureWarning:alert]: NS224NSM100 (S/N 123456789) shelf 0 on channel 0x temperature warning for Temperature sensor 7: non-critical status; overtemperature warning. Current temperature: 88 C
(190 F). This element is on the unknown location
[node_name: dsa_worker4: ses.status.temperatureWarning:alert]: NS224NSM100 (S/N 123456789) shelf 0 on channel 0x temperature warning for Temperature sensor 13: non-critical status; overtemperature warning. Current temperature: 88 C
  • 1時間ごとのEMSエラー:
[node_name: statd: monitor.shelf.warning:error]: Fault reported on disk storage shelf attached to channel 0x. Check fans, power supplies, disks, and temperature sensors.
  • storage show fault AutoSupportの出力例:
Enclosure Status: non-critical
Channel: 0x
Shelf: 0
Shelf Type: NS224NSM100
Module Type: NSM100
Temperature Sensors:
Element Status      Status Bytes  Status Descriptions
  1: OK         01,00,2A,00
 12: OK         01,00,2E,00
 13: NONCRITICAL     03,00,6C,04   OT WARNING
 14: OK         01,00,3C,00
 17: OK         01,00,3D,00
Enclosure:
  1: OK         01,00,02,00   FAIL
  • Environment AutoSupportの出力 例:
Channel: 0x
   Shelf: 10
   SES device path: local access: 0x.10.1.99
   Module type: NSM100; monitoring is active
   Shelf status: non-critical  condition
   SES Configuration, shelf 10:
    Temperature Sensor installed element list: 1, 2, 3, ...15, 16, 17; with error: 13
   Shelf temperatures by element:
    [1] 19 C (66 F) (ambient)  Normal temperature range
    [12] 22 C (71 F)  Normal temperature range
    [13] 88 C (190 F) Overtemperature warning!
  • ::> storage shelf show 出力例:
Temperature:
         -- Thresholds °C --
   Temp Is     Low  Low High High Operational
 ID  Â°C Ambient Crit Warn Crit Warn Status        Sensor Location
  1   19 true     0   5   52   47 normal        ambient temp sensor on ODP board
  2   24 false    0   5   60   55 normal        temp sensor on midplane left
  7   35 false    0   5   90   85 normal        CPU package on top module
 12   22 false    0   5   65   60 normal        bottom module temp sensor near midplane
 13   88 false    0   5   90   85 over-temperature   CPU package on bottom module
 14   45 false    0   5   85   80 normal        Ethernet port 1 on bottom module
  • storage fault 出力例:
::> system node run -nodde node_name -command storage show fault
1: OK                01,00,27,00
6: OK                01,00,33,00
7: NONCRITICAL       03,00,6C,04   OT WARNING
8: OK                01,00,4C,00
17: OK                01,00,44,00
New to NetApp?
