ZAPI コールで応答が 90 秒以内に受信されない場合は、空の結果が返されます
環境
- ONTAP 8.3
- ONTAP 9
- iteration ZAPI コール
問題
繰り返し ZAPI は、応答が 90 秒以内に受信されない場合に空の結果を返します。
• Query: <?xml version="1.0" encoding="UTF-8"?> <netapp xmlns="http://www.netapp.com/filer/admin" version="1.170"> <snapshot-get-iter> <max-records>100</max-records> <query> <snapshot-info> <name>*</name> <snapshot-version-uuid>xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx</snapshot-version-uuid> </snapshot-info> </query> </snapshot-get-iter> </netapp> • “Failed” Attempt (ZAPI response taking longer than 90 seconds, with 0 records and the next-tag): <?xml version='1.0' encoding='UTF-8' ?> <netapp version='1.170' xmlns='http://www.netapp.com/filer/admin'> <!-- Output of snapshot-get-iter [Execution Time: 90649 ms] --> <results status='passed'> <next-tag> <snapshot-get-iter-key-td> <key-0>vserver</key-0> <key-1>volume</key-1> <key-2>23742</key-2> <key-3>2am.2021-03-09_0210</key-3> </snapshot-get-iter-key-td> </next-tag> <num-records>0</num-records> <volume-errors> <volume-error> <errno>13023</errno> <name>other_volume</name> <reason>Unable to get information for Snapshot copies of volume "other_volume" on Vserver "vserver". Reason: Volume not online. </reason> <vserver>vserver</vserver> </volume-error> </volume-errors> </results> </netapp> • “Successful” Attempt (no next-tag): <?xml version='1.0' encoding='UTF-8' ?> <netapp version='1.170' xmlns='http://www.netapp.com/filer/admin'> <!-- Output of snapshot-get-iter [Execution Time: 50034 ms] --> <results status='passed'> <attributes-list> <snapshot-info> <access-time>1616803607</access-time> <afs-used>228271562752</afs-used> <busy>false</busy> <compress-savings>0</compress-savings> <compression-type>none</compression-type> <cumulative-percentage-of-total-blocks>13</cumulative-percentage-of-total-blocks> <cumulative-percentage-of-used-blocks>27</cumulative-percentage-of-used-blocks> <cumulative-total>92245576</cumulative-total> <dedup-savings>232762634240</dedup-savings> <dependency/> <inofile-version>4</inofile-version> <is-7-mode-snapshot>false</is-7-mode-snapshot> <is-constituent-snapshot>false</is-constituent-snapshot> <name>snapshot_name</name> <percentage-of-total-blocks>1</percentage-of-total-blocks> <percentage-of-used-blocks>2</percentage-of-used-blocks> <performance-metadata>0</performance-metadata> <snapshot-instance-uuid>xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx</snapshot-instance-uuid> <snapshot-version-uuid>xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx</snapshot-version-uuid> <total>4490436</total> <vbn0-savings>33943552</vbn0-savings> <volume>volume</volume> <volume-provenance-uuid>xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx</volume-provenance-uuid> <vserver>vserver</vserver> </snapshot-info> </attributes-list> <num-records>1</num-records> <volume-errors> <volume-error> <errno>13023</errno> <name>other_volume</name> <reason>Unable to get information for Snapshot copies of volume "other_volume" on Vserver "vserver". Reason: Volume not online. </reason> <vserver>vserver</vserver> </volume-error> </volume-errors> </results> </netapp>
