System Manager ONTAPのアップグレード中にScriptExecutionとエラーの初期化に失敗しました
環境
- ANDU(自動無停止アップグレード)
- ONTAP 9
- System Manager
問題
- System ManagerからのONTAPアップグレードの開始時に検証が失敗する
- ONTAP CLI(コマンドラインインターフェイス)でチェックインすると、次のエラーが表示されます。
::> cluster image show-update-progress -instance
Upgrade Stage: Upgrade from <current ONTAP verison> to <target ONTAP version>
Update Phase: validation
Phase Status: paused-on-error
Phase Duration:
Phase Comments: 0 of 4 validated. Error: Internal error. Initialization failed, Action: Verify that all nodes are healthy using the "cluster show" command, then try the command again.
Elapsed duration of the phase: <time>
Estimated duration of the phase: <time>
Phase Description: Pre-update checks
Subsystem Name: ScriptExecution
Subsystem Status: Error
Subsystem Details: Error: Internal error. Initialization failed
Subsystem Action: Action: Verify that all nodes are healthy using the "cluster show" command, then try the command again
Status: Paused - An error occurred in "Pre-update checks" phase. The update cannot continue until the error has been resolved. Resolve all issues, then use the "cluster image resume-update" command to resume the update.
- クラスタが正常な状態でアラートはありません:
::> cluster show
::> system health alert show
