メインコンテンツへスキップ
Active IQ Unified Manager「Cluster monitoring failed」または「Cluster not reachable」アラートがONTAPクラスタのネットワーク ラグにより発生
204
Visibility:
Votes:
0
Category:
active-iq-unified-manager
Specialty:
OM
Last Updated:
環境
  • Active IQ Unified Manager 9.6 + (UM)
  • Oncommand Unified Manager 6x/7x/9.x (UM)
  • すべてのOSプラットフォーム
問題
  • Cluster monitoring failed ランダムなクラスタでランダムな時間に受信したアラート
  • Cluster cannot be reached 電子メールアラートが断続的に発行され、その後のポーリングで古くなる
  • au.log:
2020-03-19 06:35:07,290 ERROR [pool-3-thread-956] c.o.s.a.d.n.NetAppOCIEArchivePerformancePackage (NetAppOCIEArchivePerformancePackage.java:307) - Failed to get archive file names from zapi. java.net.ConnectException:
Connection timed out (Connection timed out)
at java.base/java.net.PlainSocketImpl.socketConnect(Native Method) ~[?:?]
... 20 more
Wrapped by: com.onaro.sanscreen.acquisition.framework.datasource.DataSourceErrorException: Communication problem with the cluster: <cluster_ip>
at com.onaro.sanscreen.acquisition.framework.datasource.DataSourceErrorException.createWithEnhanced
DataSourceErrorException.java:73) ~[au-framework.jar:9.6.0-2019.06.J5087]
  • ocumserver.log:
[com.netapp.ipc.jms.OCIE_Events] OCIE JMS notification message received: {WarningCount=0, DatasourceName=x.x.x.x, DatasourceID=12,
 Error0_ClusterManagementIP=x.x.x.x, PackageName=netappfoundation, TotalReportTime=569, PollStartTime=1591613772703, ErrorCount=1,
 Success=false, DurationTime=23248, Error0_Message=Failed to connect to the cluster., TotalZAPITime=-1, NotificationType=PACKAGE_COMPLETED, Error0_Type=NETWORK_ACCESS_FAILURE, UpdateTime=1591613796437, Error0_Port=443, MessageType=PACKAGE_NOTIFICATION,
 Error0_Zapi=service-processor-get}
2025-07-16 17:08:22,040 INFO [oncommand] [org.springframework.jms.listener.DefaultMessageListenerContainer#2-1] [com.netapp.ipc.jms.OCIE_Events] OCIE JMS notification message received: {WarningCount=0, DatasourceName=x.x.x.x, DatasourceID=24, Error0_ClusterManagementIP=x.x.x.x  PackageName=netappstorageperformance, PollInterval=300000, PollStartTime=-1, ErrorCount=1, SampleTime=-1, Success=false, DurationTime=-1, Error0_Message=connect timed out, NotificationType=PACKAGE_COMPLETED, Error0_Type=NETWORK_ACCESS_FAILURE, UpdateTime=1752700102040, Error0_Port=443, MessageType=PACKAGE_NOTIFICATION}
New to NetApp?
