メインコンテンツへスキップ
SnapCenter解決ガイドのバックアップ、クローン、ホスト、ポリシー、およびリソースグループの削除
6
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
snapx
Last Updated:
環境
  • SnapCenter サーバ( SC )
  • SnapCenter プラグイン
回答
オブジェクト タイプ トピック 解決策
バックアップ
方法
トラブルシューティング
  • Failed to delete backup as there are clone(s) created from this backup
  • Cannot delete mounted backup or Failed to delete backup as the backup is already mounted.
クローン
方法
トラブルシューティング
ホスト
方法
トラブルシューティング
  • Failed to find host (host.domain.com). Verify if the host is up and running and check the DNS and firewall settings
  • Host name.domain.local is not registered with SnapCenter or is not DNS resolvable. Please try with a fully qualified name
ポリシー
方法
トラブルシューティング
  • This policy has Resource Group attached. Please detach the policy from Resource Group before removing the policy
  • This <policy_name> policy has backup attached. Please remove the backup first before removing the policy
  • This NetApp.DataProtection.BuildingBlocks.Contracts.SmPolicy policy has backup attached
リソース グループ
方法
トラブルシューティング
  • Resource group backup(s) are mounted. Please unmount backup(s) before removing the resource group
  • Failed to delete Resource Group: Backup component not found with resource id
  • Backup Deletion Failed: Backup <snapshot name> has mounts, cannot be deleted, unmount and retry again
  • Failed to delete resource group. Did not find any of the datastores or virtual machines to backup: [Datastore:datastore-####]
  • Remove-SmResourceGroup : The remote name could not be resolved: '<Host_FQDN>'
追加情報
AdditionalInformation_Text
